Suggestions
Audio Converter
[Есть решение] Ручной ввод параметров кодека
Poll
Ваше мнение? / What do you think?
За / I need this option too
1 (33.3%)
Нейтрален / I don't care
2 (66.7%)
Против / Useless fo me
0 (0%)
Total Members Voted:
3
Pages:
All
Topic: [Есть решение] Ручной ввод параметров кодека (Read 18890 times)
Re: [Есть решение] Ручной ввод параметров кодека
Reply #15 on:
August 06, 2025, 01:13:48 »
sveakul
Карма: +81/-1
Edit: I didn't even realize Artem had already posted a Helix encoder plugin!
https://www.aimp.ru/?do=catalog&rec_id=1334
Moderators, feel free to remove my post. Wasted time, but I learned a lot doing it "from scratch."
AIMP 5.40.2689 Portable, 64-bit
To give you an example of how adding an encoder is done, I have attached a format converter for Helix MP3 (hmp3.exe). This is the latest version 5.2.4 from May 31, 2024, 64-bit.
This is an alternative mp3 encoder with an extended high end and other small quality improvements. I provided only one "preset" option, for highest quality (about the equivalent of Lame using V0), but you can add more using the .xml file as a guide.
You can read about it here:
https://wiki.hydrogenaudio.org/index.php?title=Helix_MP3_Encoder
and at
https://hydrogenaudio.org/index.php/topic,123331.0.html
To Install:
With AIMP closed, manually unzip the folder "enc_helix", which is inside the attached .7z file, directly into the AIMP "Plugins" folder. Do NOT try to add it with the plugins "Install" option in Preferences.
Start AIMP. Go to Utilities->Audio Converter, and select "Helix MP3" from the Format choices.
Last Edit: August 07, 2025, 00:24:12 by sveakul
Reply #16 on:
October 08, 2025, 12:13:03 »
Skandy
Skandy
Thanks!
Pages:
All
Suggestions
Audio Converter
