Question about AIMP Control Plugin
Topic: Question about AIMP Control Plugin (Read 3381 times)
March 17, 2025, 07:54:49 »
tarufetti
Карма: +1/-0
Hello. I hope you can help me with this question. I want to use the AIMP Control Plugin. I have Windows 10, 64-bit.
What version of AIMP can I use that won't give me problems with the plugin? If I'm not mistaken, the plugin only works for 32-bit, right? I suppose I should choose AIMP for 32-bit, but I don't know which version, 3, 4, or whichever. With the latest version, v5.40, the plugin doesn't appear.
Sorry, I don't want to use monkeymote. I want the AIMP Control Plugin. Or at least exhaust all the other options.
Thanks.
Re: Question about AIMP Control Plugin
March 17, 2025, 08:17:14 »
Карма: +3196/-77
AIMP Control Plugin is 3rd party plugin, it was abandoned by its author
March 17, 2025, 23:29:56 »
tarufetti
Карма: +1/-0
I didn't know that. Thank you very much.
March 28, 2025, 19:17:30 »
Kristio
Карма: +1/-0
https://aimpremote.blogspot.com/
works great. Win 10, Aimp 5 32-bit
April 09, 2025, 08:51:43 »
tarufetti
Карма: +1/-0
@Kristio My PC is 64-bit. Even though I install Aimp 32-bit, I can't install the plugin, which I downloaded from the blog. It installs, but then it doesn't appear in Aimp.
Well, thanks anyway. Maybe it's just a matter of waiting for that project to continue. The plugin and the Aimp Remote Control app really have no comparison with the rest.
But the most important thing, the player, keeps getting better and better, and there's no other like it. So thanks for that.
