Suggestions (archive)
Implemented in AIMP v5.40
More width for Rename dialog window
Topic: More width for Rename dialog window (Read 3886 times)
February 28, 2025, 21:46:12 »
Albi2002
I often use the Tag Editor to also edit the actual file names. Nowadays we can have long path and file names.
The current file rename dialog is quite small in width.
Couldn't it have a width at least twice as much as it has now? Or a width like the fast tag-editor window has.
It would not be necessary to navigate to not visible parts of the path + file name using the keyboard that often.
Re: More width for Rename dialog window
March 01, 2025, 00:05:25 »
Карма: +3224/-78
Please, try this build:
https://disk.yandex.ru/d/duO4BLtLaSRgFA
March 07, 2025, 15:00:39 »
Albi2002
I was not expecting such a fast reply... :-D
Found the change in Beta from 06.03.25 - looks great, works fine, width is now big enough, as far as I am concerned.
Thank you!
