Suggestions (archive)
Implemented in AIMP v5.40
Changes in Delete menu in ML
Topic: Changes in Delete menu in ML (Read 1669 times)
February 06, 2025, 15:49:15 »
xeo
Карма: +20/-0
In Local files tab in ML:
- rename "Delete selected" to "Delete selected entry", because it is not clear whether a file or just a library entry will be removed
- rename "Delete all files" to "Delete all entries", because it suggests that the files will be removed physically
- change the behavior for Delete all option, so it deletes entries only from the active group/folder (chosen from the left tree), so it can't delete whole database when only one folder is chosen. Whole database would be deleted only when (show all) is active.
Last Edit: February 06, 2025, 18:30:44 by xeo
Re: Changes in Delete menu in ML
February 06, 2025, 16:01:29 »
Карма: +3222/-78
Ok
