Suggestions
Finding missed files breaks the folder connection to the source
Topic: Finding missed files breaks the folder connection to the source (Read 8712 times)
January 23, 2025, 18:25:49 »
xeo
Карма: +20/-0
When in playlist created from the folder there is already no specific file to play, this info appears:
When we choose "Find missed files automatically" and choose/find the file, the folder loses connection to the source and can't be updated (manually "Update content" from the playlist menu). The playlist becomes a regular playlist, horizontal arrow disappears. This is not a bug, but this "Find missed files automatically" option just doesn't fit in this situation cos it breaks the playlist.
Re: Finding missed files breaks the folder connection to the source
February 03, 2025, 14:00:38 »
Карма: +3229/-78
Sure, because it modifies a source content of the playlist. I think, in this case app should suggest to synchronize with the preimage too.
February 03, 2025, 14:49:50 »
xeo
Карма: +20/-0
What do you mean it should suggest to synchronize with the preimage? If the playlist is connected to one folder, it cannot be connected to another.
Suggestions
