Can you make it portable version? I would not like to install another version to not to break the main installation.
You can play with it in last nightly build
only without "-" works.
build 2659 "&" still doesn't work
5.40.2663_Beta_internal (2025.03.02 00-50)_w64 the same
- typing "&" shows all files- when there is for example a_b.mp3 file, and I type "ab", it is not found.
