[x] [2653] Default playlists
Topic: [x] [2653] Default playlists (Read 5305 times)
January 06, 2025, 06:26:33 »
SomeDude11
From version 5.30 to 5.40 if you remove a "default playlist" they end up in the recycle bin no matter if the option "remove playlist when closing tab" is enabled or not. Can you make it like before so the default temporary playlists just disappear without going to the recycle bin? Or maybe have a separate option for that? My recycle bin is filled with "default" files. Thanks in any case.
Last Edit: January 06, 2025, 15:05:07 by Artem
