Suggestions
DennoN
Add sorting based on the format description
Topic: Add sorting based on the format description (Read 19703 times)
December 30, 2024, 01:02:14 »
xeo
Карма: +20/-0
Hi, I wanted to sort my files list on the playlist the same as it is in the Windows window (sorted by type) and I noticed that in the AIMP there is no such meta macro for sorting. There is File format, but it's not the same.
Here on the left is Windows window with few different audio types sorted by type. On the right side is AIMP's playlist sorted by file format.
Can "File type" or "Windows file type" based on the format description be added to the macros for sorting/templates?
Re: Add sorting based on the format description
December 30, 2024, 09:22:19 »
Карма: +3231/-79
What reason for?
Suggestions
DennoN
