[x] [2652] Delete via hotkey changed
Topic: [x] [2652] Delete via hotkey changed (Read 5563 times)
December 28, 2024, 13:10:19 »
SomeDude11
Updating from v5.30 to 5.40 I noticed that the window which appears when you "physically delete a file" via a hotkey changed to match windows color. But now when you press that hotkey and then pres enter to delete the file it no longer works, as the window that appears is not selected. So you have to manually press the OK button using your mouse instead.
Please fix this, otherwise what would be the point of having a hotkey for this function.
Last Edit: December 28, 2024, 13:25:12 by Artem
Re: [2652] Delete via hotkey changed
December 28, 2024, 13:25:08 »
Карма: +3221/-78
It seems the window does not activate in this case. Fixed
