Suggestions
Player
Hotkeys
DennoN
Фагот
F13,F14,F15,.....,F24
Topic: F13,F14,F15,.....,F24 (Read 3030 times)
December 17, 2024, 00:10:21 »
wa1358
I'd like to be able to assign F13-F24 to hotkeys (both local and global).
It would be especially useful to be able to assign F13-F24 to global hotkeys.
Re: F13,F14,F15,.....,F24
December 17, 2024, 03:29:07 »
CkopoxoD
Карма: +151/-1
AIMP allows you to assign real buttons:
But in the case of some Fn+F1...F12 "magic" a lot depends on the keyboard driver. It can be easier to use Shift+F1...F12
December 17, 2024, 13:19:08 »
wa1358
I tried directly assigning it using software called AHK or XMBC and it worked. Thank you!!!
(In my keyboard, when I assign it with the combination of Fn and F7 , only F7 is displayed, I assign it with the combination of Fn and F16 , only F16 is displayed, and when I assign it with the combination of Ctrl, Shift and Alt, it works as is (Ctrl+F16, Shift+F16, Alt+F16, and multiple combinations of modifier keys are also possible as is (The display is also displayed in combination.)))
Suggestions
Player
Hotkeys
DennoN
Фагот
