ASIO not working as expected?
Topic: ASIO not working as expected? (Read 3198 times)
October 15, 2024, 18:45:11 »
CodenameGreyFox
I received a new DAC today, and when trying to use ASIO drivers, it seems to me that AIMP is still processing the signal.
While the file is 96.0, the DAC states that it is 44.1 and looking at AIMP's menu, it seems like it is changing the output. (See attached image)
In fact, should the ASIO driver even have the sampling rate option?
For reference, when I play the same file in Foobar2000 using the same ASIO output, the DAC correctly displays 96.0.
Re: ASIO not working as expected?
October 15, 2024, 19:14:40 »
Карма: +1408/-191
https://www.aimp.ru/forum/index.php?topic=53609.0
October 15, 2024, 19:24:06 »
CodenameGreyFox
Ok, after using google translate I see it is a design choice by the developers. So I am supposed to select the highest possible output and leave it at that, is that right?
Thank you.
