AIMP for Android v4.30
Replay gain not working
Topic: Replay gain not working (Read 2856 times)
September 26, 2024, 00:06:31 »
CraigVMN
I spent the whole day scanning my music files, applying replay gain, updating and saving the results, and yet the volume of different songs is still loud-quiet-loud...etc.
Last Edit: September 26, 2024, 16:50:40 by Soolo
Re: Replay gain not working
September 26, 2024, 12:17:02 »
Карма: +3210/-78
What app version?
What exactly you've applied?
Is replay gain normalization active?
What settings are used for that?
I think you just write replay gain values to file tags.
September 26, 2024, 16:23:00 »
CraigVMN
V 5.30.2563
I used AIMP to analyze each file for replay gain
Then I updated each
Then saved the results
How do I activate replay gain normalization?
September 26, 2024, 16:50:31 »
Карма: +1406/-190
Main menu - sound effects (dsp)
