Playlist re-adds deleted songs when I add new songs (Solved)
Topic: Playlist re-adds deleted songs when I add new songs (Solved) (Read 7113 times)
September 03, 2024, 19:20:06 »
saotome_miya
I have used AIMP on Android for quite some time without any problems and really enjoyed it. But then all of a sudden it started to behave strangely...
I had put together a playlist manually. I update that playlist on a regular basis. I delete some songs and then add others. Which worked flawlessly. But then it started to happen that when I deleted some songs and then added new songs these deleted songs where re-added. Same happens when I use "update content". And it's not just recently deleted songs. Can be songs that i deleted quite some time ago. They just don't want to go away.
I cleared the cache. I started with a completely new playlist. Nothing I've tried solved the problem.
What can I do to get rid of this VERY annoying - and actually unbearable - behavior?
Thanks!
Last Edit: September 03, 2024, 21:44:05 by saotome_miya
Re: Playlist re-adds deleted songs when I add new songs
September 03, 2024, 20:22:27 »
Карма: +3210/-78
What app version you using?
September 03, 2024, 20:27:18 »
saotome_miya
September 03, 2024, 21:19:13 »
Карма: +3210/-78
Update the app, please
September 03, 2024, 21:31:40 »
saotome_miya
Well, this was the current version on the Play store.
But when you asked for the version I looked around and saw that other sources have a newer version. Which I installed in the meantime.
It didn't solve the problem directly. The playlist still re-adds the songs. But I deleted them again and then exported the playlist and imported it again. And this imported version seems to work properly.
Thanks for the support!
Out of curiosity: Why is there an old version on the Play store?
September 03, 2024, 21:42:02 »
Карма: +3210/-78
Quote from: saotome_miya on September 03, 2024, 21:31:40
The update is being rolled out in several stages.
September 03, 2024, 21:43:34 »
saotome_miya
I see.
Thanks again for the support!
I marked the topic "solved".
