[x] [2619] Issue with ASIO output
Topic: [x] [2619] Issue with ASIO output (Read 4405 times)
August 25, 2024, 20:09:19 »
maciejak
Карма: +10/-0
Lastest Aimp 5.40 via ASIO => Rocks !!!
I have problem with song when install aimp 5.40_2619, then disapear instrument doublebass in the song in link below
https://drive.google.com/drive/folders/1T6RSwvjVRd4qIkTUdk9jXG-0PuffYeR7?usp=sharing
Last Edit: August 27, 2024, 13:28:39 by Artem
Re: [2619] Problem with song in Aimp 5.40 beta
August 26, 2024, 22:54:57 »
Карма: +3221/-78
I've checked the file, it seems that it plays the same in AIMP and VCL. What exactly an issue?
Re: [?] [2619] Problem with song in Aimp 5.40 beta
August 27, 2024, 12:25:09 »
maciejak
Карма: +10/-0
In this song is solo on instrument double bass, problem is in aimp 5.40.2619 this instrument is very quiet almost not hear. In previous aimp 5.30 song is playing correctly. What i can say more ? This song is not playing correctly, aimp 5.40 just cut out this instrument. Please do something in sound engine, check everything. Must be something wrong. Please help.
August 27, 2024, 12:25:59 »
Карма: +3221/-78
What are your output settings?
August 27, 2024, 12:49:56 »
maciejak
Карма: +10/-0
I use ASIO output. On WASAPI working ok. Only ASIO have problem. Like said previous in version 5.30 working correctly.
August 27, 2024, 13:12:17 »
Карма: +3221/-78
Confirm, the ASIO has an issue. I will check it
Re: [2619] Issue with ASIO output
August 27, 2024, 13:17:34 »
maciejak
Карма: +10/-0
Thank You
