How could you rate an entire album the way you can rate a single song?
Topic: How could you rate an entire album the way you can rate a single song? (Read 3134 times)
August 22, 2024, 11:14:01 »
Biff
Карма: +4/-0
Newest stable portable Aimp - Windows 11 unstable
How could you rate an entire album the way you can rate a single song (with the stars behind each song) or else?
Re: How could you rate an entire album the way you can rate a single song?
August 22, 2024, 11:29:17 »
JD
Карма: +109/-3
I'm using labels
August 22, 2024, 12:56:45 »
Biff
Карма: +4/-0
Could you explain this in more detail, please?
August 22, 2024, 17:21:13 »
JD
Карма: +109/-3
I usually listen to music by albums and like thumbnail view the most. For an album rating I simply assign the corresponding label to all tracks of album, in the thumbnail mode it's easy to do. My labels look like R5.0, R4.5, R4.0 etc.
August 23, 2024, 10:12:00 »
Biff
Карма: +4/-0
Thank you. How could I set thumbnail view? Could you show a screenshot or such?
August 23, 2024, 12:42:34 »
JD
Карма: +109/-3
View
RMB
August 23, 2024, 13:45:45 »
Biff
Карма: +4/-0
Ah, OK, I see. Thank you very much!
