Установка дополнительных кодировщиков в Aimp 5.40.2617 Beta 1
Pages:
All
Topic: Установка дополнительных кодировщиков в Aimp 5.40.2617 Beta 1 (Read 9619 times)
Re: Установка дополнительных кодировщиков в Aimp 5.40.2617 Beta 1
Reply #15 on:
February 08, 2025, 14:58:02 »
Alotofsilence
Карма: +1/-0
After my last reply at friday i decide to dig a bit dipper in this subject. And i compare both qaac64.exe from foobar and qaac.exe from aimp encoder set and find that they are the same size, yepp. Then completely unistall iTunes and found the same thing, as you told and confirm later, that Foobar is totally independent from Itunes installation due to additional set of iTunes components already included it Foobar. Thats quite interesting. But i was not sure, is this trick possible with AIMP at all ... but you went further and did it, thank you
At my home PC i just reinstall new AIMP x64 version and new encoder in the usual way and everything works flawlessly. But at the work PC the problem was still persists, even after bunch of reinstalls back and forth of every components involved. Then i notice, that my work PC was Windows 11 x64 was 22H2 version, while the home PC was 24H2. And i decide to update from 22H2 to 24H2. I was unable to did it erlier due to restriction of windows itself "you hardware does noe support new updates ... bla-bla-bla". But i found new solution, that allow to bypass this harware compatibility verification. And after i install it - voilla, everything works the way it should. So i think your idea about broken "hook" was correct
Last Edit: February 11, 2025, 19:21:52 by Alotofsilence
Reply #16 on:
February 08, 2025, 20:25:43 »
ss.pl
Карма: +167/-9
qaac v2.xx
https://github.com/nu774/qaac/wiki
https://github.com/nu774/qaac/releases/latest
QTFiles
https://github.com/AnimMouse/QTFiles
Read more...
Pages:
All
