can I know the options to let aimp not drain battery?
Topic: can I know the options to let aimp not drain battery? (Read 6348 times)
August 07, 2024, 09:18:54 »
drugo
Карма: +3/-0
Aimp Rocks
Hi
can i know the option to disable to don't drain battery?
1) load the songs in memory ? I have on ,but i have some 400mb single mp3 file
2) resampling method
3) volume replagain grain-on the fly and peak normalization
or other options ?
using AIMP v4.10.1422
thanks
Re: can I know the options to let aimp not drain battery?
August 07, 2024, 09:29:37 »
Карма: +3229/-78
all app drain the battery if they works.
August 07, 2024, 09:33:07 »
Robert Mădălin
Карма: +3/-87
Quote from: Artem on August 07, 2024, 09:29:37
Artem, Facebook consumes the most battery, Aimp (with closed internet (mobile data) brightness 0%, battery saver) is consumed in 2 days, if you do not use other applications besides Aimp.
