[+] [1455] Cloud storage issues
Topic: [+] [1455] Cloud storage issues (Read 17103 times)
August 05, 2024, 06:26:53 »
nanadidi
aimp_4.11.1455_Beta.apk
WebDAV
5005 port is http , 5006 port is https
They prompted different information,See picture for error message
But The PC version can be connected
Last Edit: August 13, 2024, 08:39:11 by Artem
Re: Cloud storage issues
August 05, 2024, 08:05:57 »
Карма: +3230/-78
It seems something goes wrong with the SSL. I need sometime to find any info about this exceptions
Re: [1455] Cloud storage issues
August 09, 2024, 08:26:27 »
nanadidi
Give us some feedback
I'm using Black Synology and the version information is
DS920+
DSM 7.1.1-42962 Update 6
After replacing the Webdav suite from version 2.4.5-10131 to 2.4.4-10121, I can use http connection, but there is still a problem with https, I don't know where the problem is.
August 09, 2024, 10:04:34 »
Карма: +3230/-78
Quote from: nanadidi on August 09, 2024, 08:26:27
Is the exception same? What is your device?
August 13, 2024, 04:39:05 »
nanadidi
My device is Redmi Note 11T Pro,
The system is Xiaomi HyperOS 1.0.2.0.ULOCNXM
For details about the https error message, see the attachment
In addition, there is a problem that the playlist cannot be updated, and the MP3 folder will be updated after clicking on the update content, and the list will not change. Playlists are m3u files.
August 13, 2024, 08:39:07 »
Карма: +3230/-78
The issue is related to server side. Please, refer to an answer here:
https://stackoverflow.com/questions/6825226/trust-anchor-not-found-for-android-ssl-connection
