Aimp window size
Topic: Aimp window size (Read 2935 times)
Aimp window size
July 12, 2024, 23:02:53 »
Player_Unknown
Hi, I'm new to Aimp2, currently using version 2.61 build 583 and when I try to resize de window I can only change the vertical size, not the horizontal. There is no way to enlarge the window in both directions??
Thank you!
Re: Aimp window size
July 12, 2024, 23:37:15 »
Карма: +471/-73
Limitations of the skin of that time. Install the latest version if you want the latest features.
You can also try to find another old skin, or use an old skin editor.
https://www.aimp.ru/?do=download&os=windows&cat=se
> AIMP Skin Editor v2.60.112
https://www.aimp.ru/?do=catalog&os=windows&id=0&V=260&pagesize=20
July 13, 2024, 00:12:25 »
Player_Unknown
Oh ok, thanks.
You know I've tried version 3, but windows says the software was blocked by an administrator. I don't know why, if my antivirus didn't report anything with the program.
July 13, 2024, 04:21:17 »
Карма: +471/-73
Quote from: Player_Unknown on July 13, 2024, 00:12:25
Oh ok, thanks.
Also an outdated version.
Aimp window size
