Going to show my tech ignorance here - much prefer fishing and surfing.Found the enable logging check box ok. Tell me if this sequence is correct. SD card is currently blank but the 3159 files are in the Music folder in the onboard storage..1 - Force stop of Android Music player - this should stop AIMP accessing those files.2 - remove sd card, load music files, re-install,3 - take shot of sd card properties.4 - Start AIMP, enable data logging.5 - Create playlist.6 - take screenshot to confirm number of files in playlist.7 - Find log files and copy to send to you. This last bit I am not too sure about.Regards,
