How do you prevent the "Information about the playing file" popup from opening?
Topic: How do you prevent the "Information about the playing file" popup from opening? (Read 2524 times)
April 25, 2024, 17:14:37 »
rodin
Apologies for this simple question, but I have not figured out the answer on my own yet. I am trying to locate the option to prevent the "Information about the playing file" popup from opening every time I play a track.
Thanks!
Re: How do you prevent the "Information about the playing file" popup from opening?
April 25, 2024, 18:33:19 »
almazov_music
klkl
April 25, 2024, 20:04:28 »
CkopoxoD
Карма: +148/-1
Preferences > Plugins > Scrobbling > Settings tab > Show information... checkbox
April 26, 2024, 05:40:00 »
rodin
Thank you!
