[x] [1407] AIMP for Android : Problems with URLs containing spaces in m3u
Topic: [x] [1407] AIMP for Android : Problems with URLs containing spaces in m3u (Read 18648 times)
April 09, 2024, 01:23:22 »
lorenzlm
Hello,
I've downloaded m3u playlist for BBC radio plays from Internet Archive. With most of them AIMP tells me it cannot find the files. One worked. I checked what was the difference. The working one only listed URLs and filenames that did not contain any spaces. All the other ones had file names with spaces in between the words.
Funnily, VLC doesn't seem to have this problem. But I prefer the interface of AIMP, so I'd prefer the problem to be solved. Any ideas what I could do?
Thanks and regards, Lorenz
Last Edit: April 10, 2024, 12:14:20 by Artem
Re: AIMP for Android : Problems with URLs containing spaces in m3u
April 09, 2024, 08:27:27 »
Карма: +1406/-190
share the m3u
April 09, 2024, 15:55:07 »
lorenzlm
For example, this one doesn't work, because it contains blanks between "Episode" and the episode number.
https://www.dropbox.com/scl/fi/i7jf4acl5zo880s4v4u53/Dobbs.HouseOfCards.m3u?rlkey=kuk0muwvmfdskr5md1pkns6hx&dl=0
http://archive.org/download/HouseofcardsBBCr4/Episode
1.mp3
2.mp3
3.mp3
4.mp3
5.mp3
6.mp3
I helped myself by replacing every blank with unicode "%20", using Visual Studio Code on several dozens of files. But that is a bit tedious...
Thanks in advance!
Re: [1407] AIMP for Android : Problems with URLs containing spaces in m3u
April 10, 2024, 12:14:17 »
Карма: +3221/-78
Thanks, fixed!
Re: [x] [1407] AIMP for Android : Problems with URLs containing spaces in m3u
April 10, 2024, 23:38:42 »
lorenzlm
Thanks, great! What does that mean? Next version would work with blanks in the m3u?
April 10, 2024, 23:42:23 »
Карма: +3221/-78
Quote from: lorenzlm on April 10, 2024, 23:38:42
yep
