DennoN
[2541] [x64] AIMP: "Unable to create bitmap layer" on a skin I use.
Topic: [2541] [x64] AIMP: "Unable to create bitmap layer" on a skin I use. (Read 9636 times)
March 18, 2024, 19:54:48 »
ElectronicFreez
As of version 2.30.2520 my favourite skin is broken. Version 2.30.2512 works ok. Issue still present in 2541.
When starting any song with the skin enabled. Errors are spammed.
"Unable to create bitmap layer (63220x36094)" until "Runtime error 231 at 0000000060C49B87"
Windows 10 Pro 22H2
I've attached a screenshot and the skin.
Thank you.
Last Edit: March 19, 2024, 09:39:29 by Artem
Re: [2541(2520)][x64]AIMP: "Unable to create bitmap layer" on a skin I use.
March 19, 2024, 08:38:27 »
Карма: +3210/-78
Quote from: ElectronicFreez on March 18, 2024, 19:54:48
63220x36094
Seems to big for a bitmap layer... do you use textures with that resolution?
March 19, 2024, 09:00:08 »
ElectronicFreez
Unfortunately I don't know the inner workings of the skin as I am not the creator and theres no project file. I can only speculate that it could be something related to some feature in the skin thats used when playing a song. My monitor is only 1080p and I dont think any album art is that high res.
Re: [2541] [x64] AIMP: "Unable to create bitmap layer" on a skin I use.
March 19, 2024, 12:41:50 »
Карма: +471/-73
Скин упоминался в прошлом на форуме, но автор убрал его распространение (пост). Не стоит рассчитывать, что скин будет перевыпущен.
Read more...
https://www.aimp.ru/forum/index.php?topic=61393.0
https://www.aimp.ru/forum/index.php?topic=27831.msg379374#msg379374
March 23, 2024, 23:19:05 »
gr-e
Карма: +169/-3
Open skin settings > bottom bar and toggle "Enable cover art color background", that should fix the issue
DennoN
