new Plugins not showing
Topic: new Plugins not showing (Read 14723 times)
March 03, 2024, 04:43:49 »
jdop1
Tried adding two new plug ins , and neither are showing up . Thought it was a 64 bit issue, so reinstalled the 32 bit but still a problem
aimp_YouTube and dsp_stereo_tool are the two I have tried recently.
No idea what the problem is .
Obviously, they are installed in the plugins DIR, and named correctly ,as listed above.
Last Edit: March 04, 2024, 10:28:57 by Soolo
Re: new Plugins not showing
March 03, 2024, 10:41:15 »
Карма: +477/-75
https://www.aimp.ru/files/how_to_install_addons_lang-en.txt
https://www.aimp.ru/forum/index.php?topic=44978.0
March 04, 2024, 07:13:04 »
jdop1
I was ably to get the Youtube plug in to show by editing the aimp.ini file and removing the =0 entry for that plug it
dsp_stereo_tool still not showing up
March 04, 2024, 08:07:00 »
Карма: +3235/-85
Quote from: jdop1 on March 04, 2024, 07:13:04
try to remove the "[Plugins.CachedInfo]" section from the aimp.ini
March 04, 2024, 10:12:01 »
jdop1
Yes , I had already removed all references to stereo tool that was in the INI file (from a previous install) and it now shows up correctly.
Thanks for the help.
