Suggestions
Tag editor
DennoN
Фагот
some improvments for: "Auto-tagging via online services"
Poll
Ваше мнение? / What do you think?
Мне нужна такая опция / I need this option too
0 (0%)
Меня устраивает текущий вариант / I like current behavior
1 (100%)
Против / Useless fo me
0 (0%)
Total Members Voted:
Topic: some improvments for: "Auto-tagging via online services" (Read 7439 times)
February 26, 2024, 10:03:23 »
untymage
As you can see in the image below, Aimp is missing the track title in the input search. This is because Aimp only looks up the 'Album' frame in the file metadata, and this file doesn't have an album field. However, the rest of the fields, such as Title and Artist, exist:
My second suggestion is regarding the tagging process. Currently, you can only add tags one by one. For instance, if you select multiple files and choose 'Edit tags' > 'Auto tag via...', the search bar forces you to enter a search query. It would be great if, instead, you could select a file and have it automatically autocomplete the artist and title. Additionally, I would appreciate it if the system could fetch metadata for all tracks at once, rather than one by one.
Third: the search result missing track duration:
Lastly, when a track involves multiple artists, the Artist tag contains a ';' character. This causes issues with Last.fm scrobbling, as it creates a new page on Last.fm instead of capturing the existing page.
Last Edit: February 26, 2024, 14:23:40 by untymage
Suggestions
Tag editor
DennoN
Фагот
