[+] [2533] m4a skipping issue
Topic: [+] [2533] m4a skipping issue (Read 11419 times)
January 29, 2024, 21:01:22 »
nzent
when I play m4a format audio randomly skipping time in seek bar without doing anything, When I played it another player there is no problem , only in AIMP
Last Edit: February 01, 2024, 08:45:23 by Artem
Re: m4a skipping issue
January 29, 2024, 23:10:07 »
Карма: +3230/-78
What app version?
January 31, 2024, 17:01:44 »
nzent
v 5.30.2533
64-bit (20.12.2023)
windows 11
January 31, 2024, 17:09:52 »
nzent
here is the video link -
https://www.dropbox.com/scl/fi/jqoongi38aj97me6waaj8/Recording-2024-01-31-193701.mp4?rlkey=wa7349dyiyvv4wo7slr97i106&dl=0
Re: [2533] m4a skipping issue
January 31, 2024, 21:49:41 »
Карма: +3230/-78
Can you share to me this file for analysis?
Re: [?] [2533] m4a skipping issue
January 31, 2024, 21:59:35 »
nzent
It happens randomly only in m4a types
https://www.dropbox.com/scl/fi/wgigigaeo8w5um7bae9mt/AURORA-The-Seed.m4a?rlkey=ptc5ay0lgtt4019fiadly2wp0&dl=0
January 31, 2024, 22:19:29 »
Карма: +3230/-78
Thanks, the file is:
Code:
[Select]
Format : dash
Codec ID : dash (iso6/mp41)
The dash container can be demuxed only via external codecs (AIMP has no built-in codec for dash). So, stability depended from installed codec to your OS.
P.S. On my Windows 10 the file plays without any interruptions.
January 31, 2024, 22:27:12 »
nzent
Ok doesn't matter I downloaded mp3 version of it,
Thank you 👍
