Suggestions
only add files from current folder to default playlist
Topic: only add files from current folder to default playlist (Read 9986 times)
November 24, 2023, 20:26:02 »
blackout1911
i like my folder structure on "my music" and always select tracks from there.
but when i select a track to play now it always adds up on the default playlist. after a while the default playlist gets just endless, and this makes shuffle mode then absolutely horrible.
It would be nice that when I click on a file to play, the current playlist is automatically emptied and only the files in the current folder (in which the track being played is located) are added.
i hope you get what i mean... its basically the way every other player out there handles this...
Re: only add files from current folder to default playlist
November 24, 2023, 23:38:16 »
Карма: +1406/-190
What app build?
November 26, 2023, 01:06:45 »
blackout1911
always latest (1382)
Suggestions
