Shuffle cannot be turned off in AIMP windows 10
Topic: Shuffle cannot be turned off in AIMP windows 10 (Read 2246 times)
November 17, 2023, 22:42:08 »
drusher
About 2 days ago, when I turn off shuffle (and the button is not illuminated), it still shuffles. I have been running the same version for about 2 years and made no changes. I have tried everything to fix it, including installing updates. Nothing worked, so I reverted to running 5.10.248 x64. I dont like the newer versions because all profile settings must be redone. I'm thinking that there is an error in the profile file holding settings. Can I edit/fix that file? Any other suggestions?
Re: Shuffle cannot be turned off in AIMP windows 10
November 18, 2023, 01:39:35 »
Карма: +1397/-187
Ctrl+Q - screenchot
November 21, 2023, 00:08:54 »
drusher
Actually shuffle can be turned off. It has worked fine for years. I rebooted the PC and that cleared the problem. I'm not sure if shuffle works on newer versions. I am running an older version because losing all my settings and playlists is a showstopper.
