[VST2] Bass Gnomes – Clarity
Topic: [VST2] Bass Gnomes – Clarity (Read 3576 times)
November 11, 2023, 21:27:41 »
Недавно наткнулся в интернете на весьма интересный VST X32 плагин Clarity от Bass Gnomes,хорошо спелся с vst плагинами Tube Tech Pe 1C и Unlimited,появилось в звуке больше четкости и воздуха.Плагин полностью бесплатен.
Last Edit: November 13, 2023, 15:15:35 by Artem
Re: Bass Gnomes – Clarity
November 11, 2023, 21:28:13 »
Last Edit: November 13, 2023, 03:16:38 by tropika
November 12, 2023, 01:11:06 »
Еще xорошая связка этого плагина получилась со старой версией iZotope Ozone 5,его пресетом 4-Band Master 12AX7 Tube,звучит как Hi End
November 12, 2023, 01:34:16 »
Карма: +474/-74
Почему решили дать ссылку на какой-то левый сайт?
У плагина есть работающий сайт:
https://bassgnomes.wordpress.com/clarity-vst/
Прикрепил архив к сообщению, чтобы была возможность скачать здесь.
Clarity 1.0 32 Bit
Clarity uses phase shifting and comb filtering to enhance the clarity of the audio signal. Clarity also integrates Full Phase VST effect in-line with it’s audio routing.
The phase of either the left or right channel of the effects mix can be inverted. You can also cross-mix the Left and Right Channels, swapping them entirely if need be.
Clarity works great on clearing up percussion, strings, and many other things.
Update 4-25-2012: Incorporated updated Full Phase Effect in-line.
Update 5-31-2012: Added Ability to cross-mix Effect L/R Channels. Added ability to invert phase of Left/Right Effect Channels.
Clarity 2.0 64 bit
Clarity 2.0 is a rework of the original Clarity 32 bit. The additional options have been removed in favor of a more simple interface with better results. Clarity is based on an effect caused by short millisecond delays chained and inverted against the original signal, which produces a high frequency stimulation as well as audible clarity improvement. Clarity 2.0 is 64 bit.
November 12, 2023, 02:55:20 »
Сорри что нашел то выложил,спасибо за вторую версию этого замечательного плагина!
