disable shuffle mode
Topic: Remove / disable shuffle mode (Read 6696 times)
November 01, 2023, 16:33:43 »
jaegerschnitzel
By accident I often activate shuffle mode. Is there a possibility to totally disable, remove or block this feature?
Re: Remove / disable shuffle mode
November 01, 2023, 21:14:45 »
Карма: +3229/-78
You can modify skin using skin editor tool
November 01, 2023, 23:17:29 »
jaegerschnitzel
Thanks
