| AIMP for PC > Обработано / Processed |
| [+] [2524] [x64] AIMP: Cannot change device parameters on Sound Output |
| << < (3/3) |
| Venomaster:
If I set WASAPI Exclusive event or push mode - yes everything is correct as per OS. But WASAPI: Windows default shows nonsense. System is configured as stereo. |
| Artem:
--- Quote from: Venomaster on September 16, 2024, 17:27:05 ---If I set WASAPI Exclusive event or push mode - yes everything is correct as per OS --- End quote --- In this case, all supported parameters are listed. --- Quote from: Venomaster on September 16, 2024, 17:27:05 ---WASAPI: Windows default shows nonsense --- End quote --- It shows as OS set up. --- Quote from: Venomaster on September 16, 2024, 17:27:05 ---System is configured as stereo --- End quote --- As I say before, system has set up for 7.1 playback, but only left + right channels are enabled. Anyway, in this case, the app shows the data that listed by OS. |
| Navigation |
| Message Index |
| Previous page |
