[x] [2526] [x64] Stream lyrics will appear, then disappear from Info Box
Topic: [x] [2526] [x64] Stream lyrics will appear, then disappear from Info Box (Read 8544 times)
October 28, 2023, 03:07:11 »
sveakul
Карма: +81/-1
AIMP 5.30.2526 RC x64 Portable, Charm skin, Windows 10 22H2.
On radio streams sending metadata searchable with aimp_webLyrics plugin, lyrics will appear, then disappear after about 10 seconds. But they will return and stay in Info Box after station is double-clicked to restart it. Does not happen every time but often enough to be immediately noticeable after a number of stations. Did not happen with 5.30.2524 RC x64 Portable.
Last Edit: October 31, 2023, 15:43:00 by Artem
Re: [2526] [x64] Stream lyrics will appear, then disappear from Info Box
October 31, 2023, 15:42:57 »
Карма: +3211/-78
Catched it. Fixed
