[x] [2524] Tag editor wont save album arts and lyrics settings
Topic: [x] [2524] Tag editor wont save album arts and lyrics settings (Read 10031 times)
October 21, 2023, 22:32:25 »
JohnnyIsFire
Карма: +7/-2
Prove Yourself & Rise
Tag editor wont save album arts and lyrics settings at all, i try to apply em and when i close the editor and i reopen it are the default ones for those, the rest is ok!
reset the setting and clean install wont make it work at all.
using the latest v5.30.2524 RC
Last Edit: October 23, 2023, 11:41:09 by Artem
Re: Tag editor wont save album arts and lyrics settings
October 22, 2023, 11:51:06 »
Карма: +3193/-76
Can you record a small video with your actions?
October 22, 2023, 12:53:39 »
JohnnyIsFire
Карма: +7/-2
Quote from: Artem on October 22, 2023, 11:51:06
maybe no need. cause none setting keeps saved whatever i do revent to defaults even on clean aimp install
album arts and lyrics tab settings wont keep the settings saved
Last Edit: October 22, 2023, 15:26:58 by JohnnyIsFire
October 22, 2023, 15:26:40 »
JohnnyIsFire
Карма: +7/-2
i make a video to help better, here is the link:
https://1drv.ms/v/s!AkNLKz2__WLngiiQd8URWD1VKcfz?e=ep8L0y
Re: [2524] Tag editor wont save album arts and lyrics settings
October 23, 2023, 11:41:05 »
Карма: +3193/-76
Oh, you are talking about auto-find settings! I misunderstand you in beginning
Re: [x] [2524] Tag editor wont save album arts and lyrics settings
October 23, 2023, 11:41:15 »
Карма: +3193/-76
Fixed
October 23, 2023, 15:11:26 »
JohnnyIsFire
Карма: +7/-2
Quote from: Artem on October 23, 2023, 11:41:15
Fixed
the settings i uncheck wont save on program close, yeap! thank you for the quick fix!!!!!!!!!!!!!
