Connected via bluetooth plays music HIGHLY distorted and at a very slow speed
Topic: Connected via bluetooth plays music HIGHLY distorted and at a very slow speed (Read 8815 times)
October 02, 2023, 06:01:50 »
musicollector
I am using Sennheiser Wi Fi earbuds with a Shanling M3 Ultra running the latest version of AIMP. When connected through bluetooth, AIMP plays music HIGHLY distorted and at a very slowed down speed. The native music player plays the same music fine both on bluetoooth and wired. AIMP plays normally on wired but on bluetooth this problem happens. I have installed various versions of AIMP going back to 2020, but the same issue is happening. I have turned off the EQ on the native player and AIMP for good measure, to no avail.
Re: Connected via bluetooth plays music HIGHLY distorted and at a very slow speed
October 02, 2023, 08:27:27 »
Карма: +1406/-190
Preferences - Sound - Output - Output Method - try different ones
October 03, 2023, 02:28:57 »
musicollector
Thank you for the response. Tried that, to no avail.
I have three options: Auto, OpenSL, AudioTrack, and AAudio. It used to be on Auto when this problem started. So, I tried each one, rebooted and it played perfectly, but only for about 30 seconds to a minute. Then, the above problems returned. The strange thing is that it used to play just fine on this DAP all these months over bluetooth. Something happened and I have no clue. The native player plays fine but I love AIMP's sound and functionality.
October 04, 2023, 19:34:43 »
musicollector
Since I see no further advice, I will move to some other software. Thanks for your time.
October 04, 2023, 21:14:01 »
Rfx9123
Завсегдатай
If possible, try to set up the WiFi connection at 5GHz.
October 05, 2023, 02:38:21 »
musicollector
But I am not even connected to Wi Fi. I have turned off Wi Fi and am using only Bluetooth.
