How to add smb share correctly
Topic: How to add smb share correctly (Read 17698 times)
September 14, 2023, 02:02:13 »
CLKRUN
hello all,
how can i control smb share of my server. I use smb v2.
Other apps like Samsung My Documents, Samba Player, jetAudio my share works.
But the syntax to enter is smb://Server_name(or IP)/path/to/files
But whenever I paste my path it shows <unavailable>.
I think in this case the logfile will be useless?
Thank You!
(Sorry couldn't resize with bbcode)
Last Edit: September 14, 2023, 02:15:51 by CLKRUN
Re: How to add smb share correctly
September 14, 2023, 03:04:59 »
Карма: +476/-74
https://www.aimp.ru/forum/index.php?topic=39542.msg435643#msg435643
September 14, 2023, 03:17:41 »
CLKRUN
Hello Alexei,
don't work.
September 14, 2023, 03:32:55 »
Карма: +476/-74
https://www.aimp.ru/forum/index.php?topic=71502.0
Maybe you are connecting in the wrong place? The music library only supports internal storage.
You need to connect in a playlist.
September 14, 2023, 03:34:32 »
CLKRUN
okay, thought i can use smb share to my server directory and play .flac files like with the windows aimp.
February 28, 2024, 18:06:03 »
kencanvey
Hi
Just having a fiddle with this and found that if you remove SMB// and just put the network address (192.168.1.1 or whatever yours is) it should work.
