[+] [2435] AIMP not play DSD files
Topic: [+] [2435] AIMP not play DSD files (Read 10893 times)
September 07, 2023, 03:06:35 »
fabianmarshallbb
Карма: +0/-1
I like loud music with AIMP.
Install the latest version of AIMP 5.11.2435
, Resulting in the player simply staying at "Opening" but never able to do so and ends up skipping to the next track (which also doesn't play due to being DSF/DSD)
What can I do to solve this problem?
Last Edit: September 08, 2023, 01:41:17 by fabianmarshallbb
Re: [?] [2435] AIMP not play DSD files
September 07, 2023, 08:30:38 »
Карма: +3199/-77
Can you share on of these tracks that lead to hang the app?
September 07, 2023, 10:06:35 »
fabianmarshallbb
Карма: +0/-1
It tries to play my other albums, but now the app shows me the message on the screenshot
Does it seem something related to Decoder?
DSD | "Open File" or "Decoder not Found for this Format"
DSF | "Open File" or "Decoder not Found for this Format"
DFF | "Decoder not Found for this Format"
m4a | "Decoder not Found for this Format"
https://www.mediafire.com/file/whi4eae9b8dv5cb/08_-_Midnight_Man.dff/file
September 07, 2023, 10:11:25 »
Карма: +3199/-77
Quote from: fabianmarshallbb on September 07, 2023, 10:06:35
Ensure that the "Direct Stream Digital" plugin is loaded.
P.S. the file was played fine on my side
September 07, 2023, 10:36:01 »
fabianmarshallbb
Карма: +0/-1
They don't show up for me in plugins, Decoders, they don't even show up as disabled
, they just don't show up
, so I'm going to install the Beta and see if that fixes the problem
So I installed a Beta version and vuala Problem solved!! (screenshot)
Now the question is, why were the Decoders disabled and did not appear in the normal version? Was there a problem during the update???
September 07, 2023, 12:59:23 »
Карма: +3199/-77
Apparently, once upon a time you turned off the plugin as unnecessary. By default, AIMP loads all plugins
Re: [+] [2435] AIMP not play DSD files
September 08, 2023, 01:41:02 »
fabianmarshallbb
Карма: +0/-1
But never disable plugins, just one day they don't want to work, and that happened when I upgraded to the latest version
It's strange, it's solved anyway, thank you very much Artem for helping me discover the problem
, regards
