Is it possible to search local files using multiple keywords?
Topic: Is it possible to search local files using multiple keywords? (Read 2887 times)
August 28, 2023, 18:40:32 »
harryj
Hello everyone,
I really like AIMP's folder management system, but there's one aspect that I can't figure out.
For example, I would like to filter out local folder with name "Beethoven" and "symphony" (e.g. "Beethoven - Symphony No. 5" and "Beethoven Symphony No.6")
With the default settings, it seems that only single keywords can be used for searching. In other words, I'm unable to simultaneously filter out the folders where both of these keywords are present.
I've tried using the syntax like "Beethoven+symphony" for this purpose, but it didn't produce the desired multi-keyword search effect. Also, I couldn't find any relevant configuration options.
Are there any applicable search syntax or related configuration options that can enable this feature? Thanks!
Best regards
