Optimizing Audio Quality
Topic: Optimizing Audio Quality (Read 12227 times)
August 23, 2023, 14:03:13 »
BobbyNeal
"I'm currently utilizing an AUNE USB Mini DAC-Amplifier connected to a Sony VAIO laptop running 64-bit Windows 10. My aim is to optimize the quality of the audio output. When I navigate to the AIMP Playback options and select WASAPI: Windows default or WASAPI: Speakers (USB Audio DAC), the settings display 48000 Hz and 32 Bit. However, if I opt for WASAPI Exclusive (Event): Speakers (USB Audio DAC), the second parameter shifts to 16 Bit. Regardless, when I play HiRes audio files like those at 192 kHz and 32 Bit, the AIMP Options present the following data:
Input: 192000 Hz / 32 Bit (Float)
Output: 48000 Hz / 32 BitIs there a way to achieve a 192000 Hz output?"
Last Edit: August 23, 2023, 14:11:14 by Soolo
Re: Optimizing Audio Quality
August 23, 2023, 14:08:58 »
Карма: +1406/-190
August 23, 2023, 21:56:24 »
sveakul
Карма: +81/-1
In addition to checking where Soolo indicated in your Windows options, also be sure you have set up AIMP to output a 192khz sample rate in Prefs/Playback:
August 22, 2025, 02:08:14 »
burrito97
hola donde encuentro la opcion que mencionas, deseo revisar la frecuencia de muestreo. Instale la versión portable 5.40.2683 y ya busque , porque me da temor a dañar mis parlantes
August 22, 2025, 12:20:14 »
Choveka
Карма: +45/-8
Посмотрите картинку под спойлере:
Read more...
