[X] [2505] x64 Portable: Skin windows do not "stick" to each other
Topic: [X] [2505] x64 Portable: Skin windows do not "stick" to each other (Read 8003 times)
August 12, 2023, 02:56:03 »
sveakul
Карма: +81/-1
Using the Charm classic skin and separate windows for main player, info box, playlist, visualizations, none of the windows will stick or "magnetize" to each other on their window edges so they can be moved together, as was possible in previous versions. The option to "Snap windows to screen edges and other AIMP's windows" is checked.
The app continues to produce an error report on every exit as reported previously which just may be a duplicate of the one I submitted in previous post.
Last Edit: August 12, 2023, 09:13:27 by Artem
Re: [2505] x64 Portable: Skin windows do not "stick" to each other
August 12, 2023, 09:13:15 »
Карма: +3220/-78
Yep, I already fixed it
Re: [X] [2505] x64 Portable: Skin windows do not "stick" to each other
August 12, 2023, 20:26:55 »
sveakul
Карма: +81/-1
Great! Will it be made available in the nightly builds?
August 13, 2023, 09:16:36 »
Карма: +3220/-78
So soon
August 16, 2023, 03:27:28 »
sveakul
Карма: +81/-1
This is indeed fixed in [2506], although it took a lot of manipulation to get all windows to finally stick to the chosen edges; un-checking Interface/Skins/Snap windows to.. actually helped in getting them to stay:
