How to use the podcast plugin?
Topic: How to use the podcast plugin? (Read 5749 times)
July 09, 2023, 06:09:39 »
TheVainOrphan2000
Sorry for the basic question but I recently downloaded the most recent AIMP version (with the podcast plugin already installed but I have no idea how to use it. From what i can see online, are you supposed to paste in a link into the 'Podcast subscription' window, but it always shows the 'can't download at the specified URL' message. it's compatible with soundcloud and itunes right? Would appreciate a quick rundown, or maybe theres a guide on how it works somewhere? (i checked the plugin folder for a readme doc but couldnt find anything)
Re: How to use the podcast plugin?
July 09, 2023, 11:23:51 »
Карма: +471/-73
https://www.aimp.ru/forum/index.php?topic=53887.0
See examples of links in the profile topic. If the link doesn't work, then it's not an RSS link, or a problem with parsing the XML structure. Write links in the profile topic so that you can check.
