How to transfer profiles and settings?
Topic: How to transfer profiles and settings? (Read 4743 times)
June 27, 2023, 14:02:35 »
gwt10
I'm buying a new laptop. How do I transfer the AIMP settings from the old laptop to the new?
And does it matter if it's 32bit or 64bit?
Thanks
Re: How to transfer profiles and settings?
June 27, 2023, 14:06:58 »
Карма: +1403/-189
read the help
June 28, 2023, 23:51:58 »
gwt10
The help option at the top only refers to help on how to use the forum. It doesn't mention anything about transferring my profile and settings from one computer to another.
June 29, 2023, 03:58:56 »
sveakul
Карма: +81/-1
It matters if it's 32 or 64 bit AIMP in that any plugins you are using with it must also be 32 or 64 bit. And of course, if you had a 64-bit AIMP originally then the new laptop must also have a 64-bit Windows.
June 30, 2023, 00:12:02 »
gwt10
When I go into the
File -> About
dialog box, it does not tell me whether it's 32bit or 64bit. How do I find out?
June 30, 2023, 01:38:23 »
Карма: +470/-73
Some old version? Must be x86 (32-bit). Bit depth information added after the release of x64 versions.
Additionally, you can check in the current Windows through the task manager. Turn on the architecture display column in it, and then start the player.
This is provided that it is not in the program files. And there is no mistake in choosing the path.Windows has a separate folder for x86 programs "Program Files (x86)".
