Android Auto voice commands
Topic: Android Auto voice commands (Read 11196 times)
June 06, 2023, 22:35:11 »
Progabilly
Specifically, with Android Auto voice commands, can I turn On/Off shuffle mode with a voice command? What are those commands? More generally is there a list of commands that AIMP will accept from Android Auto?
So far I am aware of Play Playlist <name of playlist>
Play <song name>.
I am guessing that there are others.
Last Edit: June 07, 2023, 04:30:29 by Progabilly
Re: Android Auto voice commands
June 07, 2023, 08:12:02 »
Карма: +3229/-78
Most voice commands are handled by Android itself, sending the final action to the app. Lets see, what Android send to the app on "On/Off shuffle mode": refer to the "About" dialog of the app, and check the "enable logging" option. Now, invoke the voice commands and send the log file to me. Please, report to me a approximate time when issue was happened.
September 02, 2023, 19:12:33 »
drussell17
It seems that Google is unwillilng to forward audio player commands to AIMP.
I ask it to Play Playlist xxxx and it tells me I need Youtube Music.
I will try the command suggested above
Dave Russell
Springfield PA USA
October 16, 2023, 08:28:20 »
dalekodaleko
I was able to create a Routine "Play music" mapped to a command "Open AIMP application and unpause music" which makes it play current track in AIMP.
I also added a routine "Open AIMP app" to show AIMP app.
