How to sort playlists by hand in Aimp 4?
Topic: How to sort playlists by hand in Aimp 4? (Read 5779 times)
May 30, 2023, 12:49:03 »
synstefana
In earlier version I was able to move playlists by holding it amd move finger up and down, now it doesn't work. Couple times I saw info that sorting is possible in playlist manager, but I can't find where.
Anyone know how to get there to be able to move playlists by hand?
Last Edit: May 30, 2023, 13:23:21 by Artem
Re: How to sort playlists by hand in Aimp 4?
May 30, 2023, 12:54:31 »
synstefana
OK, I found it, to do it I had to select this icon first.
May 30, 2023, 15:27:35 »
Rfx9123
Завсегдатай
Yes, I also had this problem after the switch, especially because it was switched from intuitive to a cumbersome call of this function. But with help from this forum it works now.
