A visual bug in Android 12
Topic: A visual bug in Android 12 (Read 6689 times)
April 20, 2023, 13:09:49 »
rado84
Карма: +3/-4
Bulgarian
6 months ago I bought a Nokia G21 and originally it was with Android 11. Then, yesterday, they finally released a system upgrade to Android 12. As usual AIMP works quite fine but I discovered a weird visual bug with the skins of AIMP when certain phone settings are chosen.
When these precise settings have been chosen in Android 12's Settings app
This happens with AIMP's interface and it happens with ALL skins:
Since I have a backup of AIMP's settings, I tried by returning AIMP's settings to default to see whether it will get fixed but it didn't, so I restored my settings.
If you could fix that visual bug, it would be great bc the phone looks a lot better with the settings shown above. I'm not a fan of huge visual elements which is the default setting for Android 12, not to mention that with smaller visual elements I can see more of the playlists without having to change playlist settings.
Last Edit: April 20, 2023, 13:44:53 by Artem
Re: A visual bug in Android 12
April 20, 2023, 13:44:43 »
Карма: +3210/-78
This is not a bug, app switched to tablet layout (because of screen density). Refer to app settings / interface and switch the layout option to phone
April 20, 2023, 16:05:46 »
rado84
Карма: +3/-4
Bulgarian
Perfect, that did it! Thanks!
I didn't even know AIMP had layout settings!
