That new versions doesn't work well form years about play mixed tracks
Topic: That new versions doesn't work well form years about play mixed tracks (Read 2469 times)
February 16, 2023, 12:59:21 »
maui.maui4
I'm still using 4.10 - 1827 Version: last that I found working well
When there are mixed tracks, altough in playback settings are cache 5 mb, or 10 mb, and pre-load next track.... There is a strange way to go to the current track to the next, a sort of little part, like the last second of the current track still no play, and it go to play the next track.
For example you can hear that very well in The Dark Side Of The Moon in the entire disc between tracks, specially in the last part of the song Any Colour You Like, when it go to play Brain Damage, the last note of the guitar in Any Colour You Like, still not hear.
The same problem still in Android version from years as well.
This is an old big problem, and for now even Winamp or XMPlay 3.4 works better than this application.
Re: That new versions doesn't work well form years about play mixed tracks
February 16, 2023, 13:04:06 »
Карма: +1406/-190
Maim menu - Sound effects - Mixing - off
February 16, 2023, 13:06:27 »
Карма: +3220/-78
Hm... any details about the settings? What cross-mixing settings are used in your case? I am not changed sound engine since v3.60...
What is album? Is it represents by separate files or it single file with CUE-sheet?
