Changes in the signal path of the internal versions after aimp_3.30.1241?
Topic: Changes in the signal path of the internal versions after aimp_3.30.1241? (Read 6116 times)
January 26, 2023, 19:13:08 »
Rfx9123
Завсегдатай
Hello, are there any changes in the signal path of the internal versions after aimp_3.30.1241?
With version 3.30.1241 I was able to really enjoy the potential of my HiRes player with AIMP, especially the airiness and the wide sound stage up to the high frequencies were a pleasure without having to increase them significantly with the equalizer.
This was probably because AIMP was able to use the player's own codec, as announced. Now I have had the last three internal versions installed for a test listen and had to realize that the brilliance has been lost. This is a deterioration and no longer a pleasure to listen to.
My Player iBasso DX160.
Re: Changes in the signal path of the internal versions after aimp_3.30.1241?
January 26, 2023, 21:03:30 »
Карма: +3230/-78
No, I have not change anything in sound engine
