Playcount ?
Topic: Playcount ? (Read 2285 times)
Playcount ?
January 23, 2023, 00:08:29 »
LoloRRR
Hi everyone,
I am an "old" user of Aimp, since years.. i have a problem : i like statistics, and I use the "playcount" and "lastplaydate" tags in the software. It works with some files, and not with others... I feel it may be linked to a access or security thing on the files, because I think it doesn't work with all the newest files, and it works with older ones.. I checked and rechecked the properties of the files, security access.... i can't find out why it doesn't work, all my directories or files have the same settings and are located in the same "music" directory.
If someone have an idea or the solution, it would be great :-) Thanks !!
Last Edit: January 23, 2023, 09:32:34 by Soolo
Re: Playcount ?
January 23, 2023, 08:21:13 »
Карма: +3220/-78
It works only for files that added to music library database
Re: Playcount ?
January 23, 2023, 09:22:55 »
LoloRRR
I added each time on my playlist, is this enough ?
Re: Playcount ?
January 23, 2023, 09:27:58 »
LoloRRR
Just added in the options "add to datadase when file played", and it works !
Thanks for your help, i tried a lot of things since months... thanks
Playcount ?
