Suggestions (archive)
Implemented in AIMP v6.00
[Planned] Add to end of playlist "Default"
Poll
Ваше мнение? / What do you think?
За / I need this option too
4 (100%)
Нейтрален / I don't care
0 (0%)
Против / Useless fo me
0 (0%)
Total Members Voted:
4
Topic: [Planned] Add to end of playlist "Default" (Read 3542 times)
January 19, 2023, 01:56:03 »
ElectricBullet
AIMP has been doing great as I've moved away from using VLC as my main music player, but there is just one option I wish it had.
Under "Open files from external applications", I wish there was an option to "Add to end of playlist 'Default'" instead of "Add to empty playlist 'Default'". What I typically do is browse through a number of folders and choose a bunch of songs from multiple different folders and double click them all to play them.
But every time I do this in AIMP, it empties the "Default" playlist first, and only plays the last songs I selected.
I suppose what I want is similar to the Drag & Drop feature, but the ability to add them to Default.
Or even the "Add to current playlist" option, but specifically for Default, so if I'm playing a set playlist, it doesn't add to that playlist.
https://imgur.com/wZhoN32
Last Edit: May 03, 2026, 19:36:23 by Artem
Re: Add to end of playlist "Default"
April 25, 2026, 07:07:11 »
raywilkins
I've been wanting this feature for about 10 years.
May 03, 2026, 19:36:01 »
Карма: +3219/-78
This feature was implemented in AIMP6 Beta 3.
