Somewhere it was mentioned that this was bad behavior of the program and it was fixed.
Namely, when the Playlist is LOCKED FROM CHANGES, the title doesn't change, doesn't follow the title in main window, so they are different.
As a comparison, I've added two screenshots (both with the latest Aimp-Version):- the variant with locked playlist, where the track information ain't available in the "tags"- and the variant with unlocked playlist, where the info is available in the "tags" (the way it always used to be) and can be easily copied for research (which can be useful for a non korean in case of korean writing
Read more...
Yes, this is correct behavior. Locked playlist MUST NOT change it content in any cases.
