Suggestions
DennoN
Add a max volume setting
Topic: Add a max volume setting (Read 15963 times)
December 19, 2022, 16:30:24 »
JohnnyIsFire
Карма: +7/-2
Prove Yourself & Rise
Well windows volume at 100% gives sound is distortion
For me at least need to keep it at 50% to have the best clean sound.
The problem is also with bitperfect asio and wasapi, need to use player volume controls cause bypasses mixer...
So i my suggestion is an option to make the player volume control not goes far from the desire volume percent!
this can help maintain the sound in clean levels!
Re: Add a max volume setting
December 19, 2022, 16:45:00 »
Карма: +3220/-78
Do you use equalizer or some another sound effects?
December 19, 2022, 17:03:00 »
JohnnyIsFire
Карма: +7/-2
Quote from: Artem on December 19, 2022, 16:45:00
never!
Using a FiiO K9 PRO ESS and a Topping D90SE - A90
When i have windows volume at 100% sound is distorted.
Need to keep it at 50% to have the best clean sound.
a workaround is a set of gain at -4.00db at player but that is not the solution
or to keep the player volume to 70% - 75%
is any other way to fix it or bypass the Windows garbage implemention? or is how the way it is?
Last Edit: December 19, 2022, 17:55:54 by JohnnyIsFire
Suggestions
DennoN
